Will they fit?
Old Aug 27, 2008 | 10:13 AM
3DFORMULA's Avatar
This is a pic of my 17x11 with 315/35/17 with 36mm backspacing. NO BFH NEEDED. Mounted them, adjusted the panhard rod to put the differential under the car correctly and drove off. 2years now without ANY fenderwell mods at all. And no spacer needed.
Old Aug 27, 2008 | 10:15 AM
Dave J's Avatar
I ran the grandsport ZR1 wheels with 315`s when mine was a street car and it took me about 15 min to clearance the inner wheel well with bfh and remove the bump stop on each side.
no spacers needed and they look badass with the 315`s on a 11 inch rim
dont put the 315`s on a 9 inch rim it looks stupid
Old Aug 27, 2008 | 06:22 PM
HavinSomeFun's Avatar
The wheels I have on the way are the 50mm offset in the rear (Grandsport) So when they get here I will BFH the inner fenders to make clearance needed. I really appreciate the help from you guys. Thats what a board is supposed to be like! and now I also need to order an adjustable PanHard Bar.....
Old Aug 27, 2008 | 07:22 PM
Formula350's Avatar
You might want to cut off the bump-stop mount. Don't know if that's BFH-able I know my 255 DR's just BARELY clear them. Probably 1/8" to 3/16" clearance.
