Will they fit?
Here is a link to the same wheels.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN:IT&ih=019
This site has sections for cars that are not 4th gen based bodies and thats when its considered appropriate to ask that question in that specifc forum.
In that light: While this is the LT1-LT4 section, 99% of those are in an F/Y/B-Body car. And probably a good 85% are F-Body. So it's just force of habit for someone with a LT1/4 engine car, to ask even non-engine related questions here. I post very few questions in the "Pontiac Firebird" section and even fewer in other sections. Why? Because they either get no replies, or little replies. I posted once in the Tuning section and got no responses, posted here and got my answers.
There are many things that float around in this section cause we all have LT1 style 4th Gens.. not necessarily Engine related.
I swapped in a LS based Engine in mine, I supposed in your eyes I'm not welcome here either..
Weak man..
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Assuming you have the correct offset, you shouldn't need spacers.
You will have to roll the wheel housing lip and do some "adjusting" with that BFH on the inner wheel housings. An adjustable panhard bar would help center your rear as with tires this tight, you'll need all the centering you can get.
I've noticed going from BFG DR's to Summitomo tires a little more space and less rubbing on those krazy turns. Proves that some tires are a bit smaller.
https://ls1tech.com/forums/showthread.php?t=120716
