Hello Dart!
Old Aug 27, 2008 | 03:59 PM
The Engineer's Avatar
Default Hello Dart!
If anyone at Dart happens to be reading this thread or you know someone at Dart, us LTX guys “really need” an aftermarket 2nd Gen block! Hey, I’m begging here and ready to sell my sole to the devil if I have to!
Here is what I think would be the ultimate aftermarket 2nd Gen iron block. 4.125” bore, w/ extra-thick cylinder walls, capable of handling a 3.875” or 4.00” stroke, 4-bolt mains, a competition oiling system, premium high-strength iron and beefed up in all the critical areas. Also, maybe a tall-deck (9.325") version block.
And, if you wanted to take it to another level, an all-out competition aluminum block with 4.190” bore sleeves and a 4.125” stroke capability.
WD
Old Aug 27, 2008 | 04:09 PM
Fixxer99TA's Avatar
That would be AMAZING....
If only...
Old Aug 27, 2008 | 05:24 PM
Mighty Whitey's Avatar
good luck... we all seem to own vehicles with the red-headed stepchild of performance motors.
no one shows any love for them.
there are a total of 3 companies making aftermarket heads for them,
only a handful of reputable head porting guys are out there that will even f*ck with them.
the aftermarket intakes that are available have minimal R&D time compared to the LSx cars, and even the one(s) that are produced, barely out perform a stock unit.
does anyone make a turbo kit for an lt1? I know of 10 companies that do for LSx owners.
we're definately getting shat on by the later model motors...
Old Aug 27, 2008 | 05:28 PM
Formula350's Avatar
Quite a few turbo kits for the LTx. One, while not the conventional style, is STS. There are others I've seen too.
Also, our blocks are pretty good for stock, only thing we could use over stock is being able to punch them out more. That 454cid SBC that World sells would be awesome for an LTx It would call for some different heads though I think, not needed but you'd want the combustion chamber styled different to be able to use bigger valves.
Old Aug 27, 2008 | 06:04 PM
TAEnvy's Avatar
I just dont think itd be profitable purely from a business standpoint unless they could slightly modify a casting of a GEN I block to make it work and cut down on R&D
Old Aug 27, 2008 | 06:28 PM
WHITEBOY_ZACH's Avatar
ok i didnt kno how to copy it correctly but in a thread by.. 1badz i believe.. he just got some dart pro 1s and a guy on here chimed in that he worked for dart... i copied his post and it has his contact info if youre interested in talking to him.
07-09-2008, 06:58 PM #42
Jeff@ramchargers
Trader Rating: 0
Posts: 52 Hey guys, I work for Dart now and do the valve job on those heads. I have them on my 94 m6 with a hot cam and full lengths and you really notice a difference. I have not been to the dyno or the track yet due to working so much overtime so I can not get you numbers there. If you guys have any questions I can try to help you the best I can.
__________________
Jeff @ Dart Racing Heads
94 Camaro Z-28 M6
95 Trans Am A4
Old Aug 27, 2008 | 07:07 PM
fergymoto's Avatar
You will likely never see an aftermarket LTX block. The market is just not big enough.
Old Aug 27, 2008 | 07:16 PM
Formula350's Avatar
If we could some how get NHRA to sanction an LTx block class, that'd open the market up loads ^_^
Old Aug 27, 2008 | 07:28 PM
fergymoto's Avatar
Yeah, if people want to run it. Let's face it, it is not the most cost effective thing to try and run fast with. Most people running LT1s are doing it because they like them, myself included. Most people in general are going to run whatever platform they can go faster, cheaper. Which in most cases is SBC, BBC, and even now the LS1 as much as cost has come down on them. There's just not enough serious LT1 people for them to have such a class. You got to figure we have probably less than 10 heavy hitter LT1s in the country. Where as there are hundreds of BBC, SBC, and LS1s going fast.
Old Aug 27, 2008 | 08:13 PM
Formula350's Avatar
Wouldn't the reverse flow help out on the strip though? With the ability to convert to non-opti systems, you'd think more people would think about it just for that reason. Or even running an LT1 not even computer controlled.
Old Aug 27, 2008 | 08:31 PM
1badzee's Avatar
I have their heads. GREAT heads. Top notch quality IMO.
Old Aug 27, 2008 | 08:37 PM
slick1851's Avatar
Just go to a SBC and stop messing around
Old Aug 27, 2008 | 08:38 PM
1badzee's Avatar
The opti is actually a real genius design, closest you can get to an accurate crank trigger. People just lose touch on maintainance and let their water pumps get old and start leaking and **** and there it goes - although if you seal it right youll never have that problem. I've taken my car through foot deep puddles going fast, ive gone through car washes, pressure washed my engine, and my opti is still up and running flawlessly, thats because i took the time to seal it. And the reverse-cooling is also genius because it cools the cylinder heads first, preventing detonation and allowing for a much higher compression ratio and more spark advance. We truely have diamonds in the rough.
Old Aug 27, 2008 | 08:39 PM
slick1851's Avatar
There really is no logical point for them to do it
SBC is far better in everyway when it comes to building a racing engine
Its not a hard swap at all, and if its not your daily driver than who cares
Old Aug 27, 2008 | 08:40 PM
slick1851's Avatar
Its not at all when it comes to a racing motor and high RPMs
Again if your racing stuff like this doesnt matter in a track car
Old Aug 27, 2008 | 08:43 PM
1badzee's Avatar
If you build it right, you won't have a problem.
Old Aug 27, 2008 | 08:53 PM
You're correct, there are many cheaper options to go fast then LTX engines. And, even more questionable are the import people "trying" to go fast with 1.8 liter engines. Hell, my 2 liter DrPepper is bigger than that!
So, a lot of going fast is simply the way you want to approach it (LTX, BBC, SBC, N/A, N2O, forced induction, nitro or whatever). It’s your choice with the performance package you want to build and feel comfortable with. Hey, I still see some 409s at the track from time-to-time.
WD
Old Aug 27, 2008 | 09:17 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Found it.
https://ls1tech.com/forums/showpost....27&postcount=9
Got some money??
Old Aug 27, 2008 | 09:19 PM
Fixxer99TA's Avatar
Wow, nice...
How much money are we talkin?
Old Aug 27, 2008 | 09:34 PM
Formula350's Avatar
That motor looks abused under the timing cover heh What's with all the extra drilling and milling?
