I done a Very Bad thing
In oil filter I saw little shiny fearings
Got it towed to ARE they say I will need this
Forged Piston ............................$520
Rings ........................................$200
Bearings.................................... $150
Oil Pump & Shaft .........................$100
Timing Gears & Chain ...................$156
Balancer ................................... $250
Heads (Cleaning) .........................$350
Crank Shaft Core (Stock) ..............$350
Rods Bolts ..................................$100
Resize Rods ..................................$80
Disassamble and Assambe ............ $750
Renry (Putting a motor in and out) $1000
Sub Total ....$3966
Grand Total...$4560
BTW its CDN which comes to $3420 USD
Any thoughts
Engine still seal
They out of what they saw from Oil Filer
Any inputs
Crate Motor ?
Jordon Musser or Shawn Salzar!
When the car was brought in, we did cut open the filter and find bearing material,He asked us how much to do the engine in his car....We gave him a quote on complete rebuild with upgraded parts, not a bone stock rebuild!
The prices you see are exactly what he was quoted, We do not do "patch jobs" here at ARE.... would we just pull the crank and put in new main bearings and crank? NO... what about all the bearing material that has gone through the rest of the engine? would we build a new short block and put on the old set of heads with out pulling them a part to check the guides,springs,valve job and replace the seals etc.... NO....
Mir was quoted on what recomend doing to do the job right!! so there`s no further issues....Also keep in mind the car has 70,000 miles on it.....
I lost the cam timing gear on my 94Z back in March, and it put junk through the bottom end of the motor. Bottom end looked ok, but popping off a main cap, and just feeling the grit that was against the bearing, was enough for me. It's getting a full rebuild. But I'm going to get a budget stroker crank instead of cleaning up my stocker.
There is NO SENSE to put a stock crank back in there if you are looking at new pistons. 383 cranks are CHEAP. No need for the $2k cranks. You can get a 383 kit for about the same price as you've got there for the rod work, rings, pistons, and crank. Do a little shopping around and have ARE quote you on a cast SCAT 383 crank, etc. I think you'll be pleasantly surprised.
-Andrew
PS Congrats on the 8.5x run, yalls car was screamin'!!!
What was wrong with your stock balancer? You sure you need a new one?
What does that entail? The minimum you should get done would be resurfacing and a valve job (as well as new springs, etc.).
Ouch. As was pointed out pick up a case scat or eagle crank for 250-300 US$. If you want a stock crank for a core pay for shipping and I will send you a few
. Rods Bolts ..................................$100
You might as well go with some eagle I beams - not really that much more and a better value IMHO.
Assuming that includes machine work and balancing?
Everything else looks fine and reasonable. For the price it cost almost nothing more to do a 383 so why not do that though?
