Lt1 engine might be going bye bye...
350 LT1 rebuilt-400 miles ago
Clevite bearings
perfect circle rings
Stock (new) oil pump
ported and polished heads
Beehive 918 springs
Proform 1.6 Rollers
Comp Cams 306
crane cam push rods
stock (new) lifters
Accell 32lb injectors
Accell adjustable fuel pressure regulator
TPIS 52mm Throttle body
CSR electric water pump
A/C delete pulley
Pace Setter long tubes
Air pump delete
EGR delete
like i said this set-up has 400 miles on it..
oh and tell us more about your heads
You should at the least get a dyno chart to see what you are really dealing with. If the heads are ported properly and with the CC306 and others items in your post, you should be very close to if not a tad over 400RWHP.
BTW there are better cam choices out there today. The CC306 is old school. Contact Lloyd Elliot for cam advice.
