ok for your blower folks...
Old Sep 19, 2008 | 09:13 PM
NSTIGATR's Avatar
Default ok for your blower folks...
ok got a question here.... got two possible builds goin in my 95 z28. m6 3.73s
heads will be stock lt-1, just cleaned up a bit. will have a p600b procharger on it with a 12 psi pulley
camshaft is a CC503, w/ crane 1.6rrs w/ the beehive springs w/ ls1 retainers
we are tryin to decide how we want to set this bottom end up. either 355 or 383. ive got a set of new howards billet 6.0" rods right now and wanted to use them. but im having trouble finding pistons with a deep enough dish for the 6" rods and 3.75" stroke if we go stroker. can someone give me some insight for this.
we can go 355 but i wanted the 383.
Old Sep 19, 2008 | 10:30 PM
NSTIGATR's Avatar
ok found a set of pistons from JE 28.00cc dished. http://store.summitracing.com/partde...8&autoview=sku
they are for 6.0" rod and 3.75" stroke. if i run the .040 cometic head gasket with standard deck height lt-1, think that will bring my comp ratio low enough?
Old Sep 19, 2008 | 10:36 PM
fergymoto's Avatar
Those pistons on a 4.030 bore would put you right around 8.8:1
Old Sep 19, 2008 | 10:43 PM
NSTIGATR's Avatar
well thats close to what we were lookin for comp wise. so now with that setup think 383 would be good choice of the two to build. will running that p600b with 12psi pulley be less effective having more cubes and longer stroke for the cfm that blower will flow?
Old Sep 19, 2008 | 10:45 PM
GMRL's Avatar
Correct me if Im wrong but I dont think the p600b will do 12 PSI. Not on a stock car let alone on that.
Old Sep 19, 2008 | 10:46 PM
fergymoto's Avatar
Sure if you got the money. If the cylinder bore is in good shape I would try to stay standard bore or .020 over. No sense in wasting the block boring it more then it needs. These blocks seem to hold up pretty good as far as cylinder bore wear. It will be stronger also
Old Sep 19, 2008 | 10:55 PM
NSTIGATR's Avatar
specs on 600B
Volute Diameter 9"
Max Supercharged HP 775
Base HP Range of Motor 200-500
(Naturally Aspirated)
Max Flow (cfm) 1200
Max boost (psi) 24
Inlet Hose Diameter 3.75
Inducer Diameter 3.37
Exducer Diameter 6.25
Outlet Hose Diameter 3
Outlet I.D. 2.62
Max Impeller RPM 60,000
internalStep-up 3.05:1
Reverse Rotation yes
Available
Self Contained no
Oil Capacity n/a
Old Sep 19, 2008 | 11:01 PM
GMRL's Avatar
Also I dont think LS1 retainers will work on LT1 valves, pretty sure they are different.
I would keep the stock crank, if you have those rods, use them.
Keep the compression around 9-9.5:1 to keep if from getting sluggish.
How much are you willing to spend on pistons?
Old Sep 19, 2008 | 11:15 PM
NSTIGATR's Avatar
gonna go forged internals all the way because i will step up heads and to a d-1 later on next summer. dont wanna run the **** outta a stock crank 150,000miles on a blown motor. only wanna build it once.
as for retainers i was told to run ls1 retainers with the springs im running. im goin to have to look further into that before i install them then.
Old Sep 19, 2008 | 11:18 PM
MEAN LT1's Avatar
If your going to go stroker I would sell the p600. Ive the the p600 on my cat before and it will make power. It will also make 12psi as well with no problem on a 355. My friend made 524@the wheels with stocks heads and all the boltons with the p600. The problem you get when you add cubes with a fi application is volume efficiency. If you go stroker I would do a D1 or an F1.
Old Sep 19, 2008 | 11:24 PM
NSTIGATR's Avatar
yea it will be next summer before i can get the D-1 head unit. for now hows the VE gonna be on the 383 havin the larger hole to fill. think itll be a weak motor compared to runnin 355 with the 600b instead?
Old Sep 20, 2008 | 12:03 AM
GMRL's Avatar
I would suggest doing the D1 the first time, otherwise it will be like doing it twice. As far as bottom ends go, theres people running stock crank and rods(studded main, ARP rod bolts) on F1As. Its all about the machine work. Just dont spin it to the moon and youll be ok. Nothing wrong with forged components, just saying it may not be neccesary. I recently upgraded my valvetrain to 918s as well.
Retainers: 63-795-16 Comp
Locks: 63-613-16 Comp
Locators: 63-4705-16 Comp
Dont forget the stem seals too.
Old Sep 20, 2008 | 12:09 AM
fergymoto's Avatar
It's a lot easier to put on a new blower than build the motor twice...
Old Sep 20, 2008 | 10:17 AM
NSTIGATR's Avatar
my main concern is building the 383 running the p600b. would i be better off power wise to build the 355 instead. dont wanna have the 600b on the 383 and it be slow as hell since it will take more air from the blower for the 383 as opposed to 355
Old Sep 20, 2008 | 10:34 AM
fergymoto's Avatar
If you are worried about the 600b choking it, no that won't happen. Would there be more power potential with a D1? By all means yes. You are going to be giving up nothing by going with a 383 over a 355.
Old Sep 20, 2008 | 01:32 PM
NSTIGATR's Avatar
i was thinking the 383 would choke out the charger since its not a large size is what i meant. the blower would have trouble tryin to keep up with the larger volume needed as opposed to the 355s volume
Old Sep 20, 2008 | 05:59 PM
Funkybird's Avatar
I went with a 355 w/ all forged internals. I used to have a p1sc and it was maxed out at 7psi so good luck hitting 12psi on that. I now have an F1A and it is maxed out at 18-19psi.
Old Sep 20, 2008 | 06:58 PM
GMRL's Avatar
Also its not a good idea to max out a blower, youll be making alot of hot air and killing it in the process.
Old Sep 20, 2008 | 07:13 PM
Funkybird's Avatar
Thats what meth plus fmic are for
