Smell of gas from my LT1
When I start my 95 LT1 after sitting for a few hours I will get a smell of gas. If i rev it as will I will get a smell of gas. Exhaust is stock besides a cat back and I did a fuel pump in it but one thing I am pretty sure of it has the original plugs and wires in it. I am going to change them for obvious reasons but was wondering if I should check anything in specific to the gas problem. I only smell it on start up and if I rev it at a stop. No fuel leaks under the hood
It's always going to smell like gas at start up. It has to run real rich.
But if you think it's worse than normal, I would check out the cats. Or have you checked the EVAP canister? Those usually fill up with gas if you over fill the gas tank.
If you have a FP gauge would be worth checking the pressure after priming (ign off-to-on) with engine not running and see if it's bleeding down through a leaking injector. If she's running original (13 year old) plugs and wires you just may have a fouled plug or crappy wire not firing at start up causing raw fuel to hit the exaust.
odds are that it is just your car burning a little rich...alot of our cars do it and that smell is normal...do the fp test and make sure its running between 40-50 and isnt fluxuating pressures..
thanks!
