low rpm stutter... searched!
Ill bet its a dirty or bad MAF sensor.
K&N oil is known to cause this if the filter is over oiled.
My truck just had the same exact problem, I tried everything wires,plugs cap rotor,fuel pump fuel filter, fuel system flush, and then all types of injector cleaner etc.
It ended up being a dirty MAF sensor. It wasnt broken so it didnt throw codes just made the truck run like **** ride when you would start driving then it would be fine once you were moving. Under wot it would stuter then start running fine.
AChotrod, you hit the nail on the head! I cleaned the MAF and put it back on. We lugged the crap out of that LT and never got one stutter or miss. We ran it hard at all rpms and it ran great. That was a cheap and easy fix. Thanks!!
