Just bought car and need HELP!!!
Old Sep 22, 2008 | 11:29 PM
david068513's Avatar
Default Just bought car and need HELP!!!
Ok I just bought a 1994 z28 vert. its got 179k miles on it, but I got it for cheap. this is the problem it has. On the way home it was fine driving but at the a light it stalled randomly. no shutter or anything. no sputtering. just dies. Put a new battery in it and that didn't work.It has a hard time starting. it will click and want to turn over but takes a min. acts like its not gonna. the SES light is on. does that do anything? it wasn't on when I bought and came on after It stalled or the battery was changed. I dont remember.
any info would help as I am new to LT1's I have third gens mainly.
Old Sep 22, 2008 | 11:31 PM
also when its idleing it has a low oil pressure(IMO) what is average for idle for a LT1?
Old Sep 22, 2008 | 11:35 PM
whitez28133's Avatar
first start with doing a voltage drop to check your battery cables, the ses light well that is important to get diag. because that could point you in the direction of the stalling, maybe vaccume leak somewhere
Old Sep 22, 2008 | 11:48 PM
one of the battery cables is alittle cut and is getting replaced. Could this be the reason for the stalling??? How do you diag. a code on a LT1? idk anything about there computers.
Old Sep 23, 2008 | 12:02 AM
Fixxer99TA's Avatar
If you have an SES light, you need to check that first.
Based off your description, Im going to say Opti... But you NEED to get it scanned, its trying to tell you what the problem is.
Get it scanned, post up the number here.... We can tell you.
Old Sep 23, 2008 | 12:10 AM
jarretthise's Avatar
sounds like an opti but then again it just clicks...if it was your opti more than likely it would crank but not run...really what it soulds like is your icm or possibly your starter...if you jump your starter does it do the same thing??
Old Sep 23, 2008 | 12:18 AM
Fixxer99TA's Avatar
Oh I missed the clicking part, what exactly is clicking? The starter I assume?
Jarretthise is right, if its clicking and not cranking theres no way its the opti...
My answer remains the same, get it scanned and you will know exactly whats wrong! Its throwing SES lights for a reason, it may be related but could be something else... I would check there first, THEN try to figure out the remaining problems (If there is any).
Old Sep 23, 2008 | 12:22 AM
lol its all good fixxer99...but man check your starter and get back to us.. these ltx cars are a pain if your a newb but after you get the hang of them i think you will like them more than the tpi motor...even know you have more room on those cars to work the lt1 is still a fun and fast motor to play with..GOODLUCK and keep us updated man
Old Sep 23, 2008 | 08:12 PM
How I check the codes?
Old Sep 23, 2008 | 10:09 PM
SS RRR's Avatar
Village Troll
Ask around your local mechanic shops. Part stores check codes for free, but I haven't seen a one that has a OBDI (which is what you have) code reader.
Old Sep 23, 2008 | 10:18 PM
lt1z28camaro's Avatar
Took mine to local chevy dealer they charged 30 bucks and it was the egr valve sticking. Had alot of the same symptoms you have, SES came on after it died at light. Never died again after, just idle issues..Take it to a shop so they can diagnose it.
Old Sep 23, 2008 | 10:29 PM
thanks,the SES isn't always on so I hope they can check it still. It started and ran perfect 4 times tonight. Everyone else I have asked Have said its the OPTi plus it has 179k and is stock so that could be it.
Old Sep 23, 2008 | 10:58 PM
My SES started coming on while driving on the highway. After it died on light, it's always on now.. So yeah, that probably doesn't help you, just giving you something to compare to haha. But good luck!
Also, if it is your opti stick with ACdelco (gm parts) when it comes to replacing it, others i hear not so good things about and am told msd isn't worth the extra $$ unless you're pushing big power.
Old Sep 23, 2008 | 11:10 PM
RedLT1Z's Avatar
how's the fuel pressure?
Old Sep 23, 2008 | 11:35 PM
Ok for the research ive done I guess. when the light is on the oil press. is almost not even there its so low though.
Old Sep 26, 2008 | 09:20 PM
you guys are missing his question clicking!! cut battery cable you say? that will cause a major voltage drop and no start replace that cable or your car will suffer a possible fire!!
Old Sep 28, 2008 | 06:02 PM
any luck with this thing man??
