The Fastest LT1's on LS1TECH.com
#202
Updated the converter and your times, but you didn't move up in the list
but what's the "new induction"? and how did the PT4000 compare to the SS?
#203
yeh..I knew it would not get me a bump
The SS4000 seems a bit better then the PT4000, but sometimes a converter is a little off.
I had a 1.41 with the SS and 1.40 with the PT. I think the induction was more my gain the the converter.
#207
New N/A times for my car, from the 2009 Shoot-Out (May 30), Warren Dempsey
10.977 @ 126.9 MPH (note: several 126 MPH passes, all N/A)
Golen 396 short block, Lloyd Elliott reworked AFR heads, Comp custom-grind SR cam. PCMforLess tuning and 4L60E tranny.
Here is the proof!
Here is the proof!
#208
Here is the proof!
Here is the proof!
#209
Also, I've got the LE reworked AFR heads and a few other upgrades this year!
Warren
#214
All updated,
Brady - your inching your way towards the 10's, good job. BTW, you mentioned new motor, do you need me to update the details of your listing?
#216
Updated it for you Ray, there were a lot of changes made (at least from what was posted before) to only get you .4ish, is there anything holding you back? You dropped almost 200# went from a 150 shot to a 200 shot, and switched to the AFR heads, were the heads ported? Sorry but just thought with the changes you made it should have went a little faster and into the 9's...
#217
#218
Guest
Posts: n/a
#220
