Mac Mids problem
Old Sep 26, 2008 | 09:52 AM
lilblackZ28's Avatar
Default Mac Mids problem
I installed my mac mids, but the header hits on the streeing shaft.The number 3 exhaust port pipe just barely.What can I do about this cuz it makes it a hard to steer.
Old Sep 26, 2008 | 09:56 AM
lt1z28camaro's Avatar
I've read that alot of ppl grind a little off of the steering knuckle to get it to clear it better, but let others chime in I havn't had this problem yet..
Old Sep 26, 2008 | 10:01 AM
baylove's Avatar
pm sent
Old Sep 26, 2008 | 10:02 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Let it clearence it self, OR take it off, get some pipe and a hammer and clearence it. Btw I hate mids.....
Old Sep 26, 2008 | 10:19 AM
Elliott's94Z's Avatar
Didn't have any issues with my Macs. BTW I hate LT's...
Old Sep 26, 2008 | 12:24 PM
Toronto_LT1's Avatar
why?
Old Sep 26, 2008 | 12:41 PM
fergymoto's Avatar
Kind of a bad idea that probably will not work. Find out which part of the shaft is making contact and clearance the shaft and/or primary as necessary. Be careful and use common sense with what you do to the steering shaft.
Old Sep 26, 2008 | 01:02 PM
PNYKLR-TA's Avatar
i agree be very careful and like they always say measure twice cut once, if you take too much off and make it unstable then it might snap and thats your steering shaft thats nothing to be messing around with.
BTW i hate headers!
haha i win!
Old Sep 26, 2008 | 01:29 PM
Dave J's Avatar
I had the same problem then I changed the motor mounts and the problem went away
Old Sep 26, 2008 | 10:21 PM
SoxXpupPeT's Avatar
my mac's went in real sweet. you could always take the header off. heat it up and hit it with a rubber mallet where its hitting and grind abit off the steering knuckle.
Old Sep 26, 2008 | 11:39 PM
Formula350's Avatar
I don't know how our steering setup is, but assuming there's a ujoint inside, you could always remove everything from the firewall and oblong the holes out just a tad. You'll obviously want to make sure you tighten down your bolts with an impact after, so it doesn't slide any. That'll keep you from having to grind down your steering shaft or denting your new headers.
You could also just need new engine mounts. Even if that doesn't fit it, it probably wouldn't be a bad thing to do anyways
Old Sep 27, 2008 | 12:16 AM
fergymoto's Avatar
Are you suggesting relocating the lower column?
Old Sep 27, 2008 | 11:04 AM
AChotrod's Avatar
How about loosening the steering column bolts and sliding it over a bit. That would be the first thing I tried.
Also just to point out again, that Every header shorties,mids or LTs, has issues regaurdless of brand.
Old Sep 27, 2008 | 11:31 AM
SnakeOiler's Avatar
As DaveJ said, new motor solved his problem. I think most people have solved this problem by doing that.
Old Sep 27, 2008 | 04:03 PM
Formula350's Avatar
Relocating? No. But doing exactly what this guy said, yes. Only I suggested oblonging the holes a bit so it would slide more, if simply loosening them wouldn't cut it.
Old Sep 27, 2008 | 04:07 PM
fergymoto's Avatar
That's what I thought. Those 3 8mm bolts that hold it in place at the firewall would hold up real well to an impact wrench
Old Sep 27, 2008 | 04:10 PM
AChotrod's Avatar
Dont use an Impact wrench. Making sure if he didnt see the eyeroll
Old Sep 27, 2008 | 04:34 PM
Formula350's Avatar
Yep, because they only make high torque impacts. No such thing as a 1/4" impact. So to you as well The more you try to make me look stupid, the worse you come across in my eyes. And your trolling is getting kind of old too.
Old Sep 27, 2008 | 04:38 PM
fergymoto's Avatar
Nice try on the 1/4" impact.
Whatever man, it just gets old seeing you trying to give expert advice all the time on subjects where you clearly have no idea what you are talking about. Maybe I just got tired of being quiet
Old Sep 27, 2008 | 07:17 PM
Formula350's Avatar
Not sure what you're insinuating by "nice try". I honestly can't believe that you wouldn't know that there are 1/4 impacts.
I'm not trying to give expert advice. I'm trying to give advice that works. If I implied that I knew everything, I'd just go out and say "Since I know everything, you should do this". And yet, 2 posts later, someone offers almost the exact same damn thing I did, but there was no lame *** retort by you for his post. Which leads me back to you turning into a troll. So I'm thinking you should just go back to being quite.
