Crossmember mounted torque arms!
You want the relocation kit that replaces the trans mount.
NOT The tunnel mount TA if its a DD or street car.
The first pic Ryan posted is the one I took off my car.
In those pics you can see how the front of the TA mounts to the tunnel brace. Under load it pivots. I do not recomend it for a steet car.
If your going to do it the TA relocation kit that replaces the trans mount is the way to go.
Link:
http://lsxextreme.com/showthread.php?p=74#post74
I might be able to give you a run for your money...
The output shaft twisted off. I fucked up the planets and all sorts of other **** inside the trans...Im not sure what went first, the housing or the output shaft, but my moneys on the shaft...
The shaft probably went, then the driveshaft flopin around in there is probably what broke the housing...
If you have any additional questions please ask and I will be glad to help.
Thank you!
Ryan
Thank you!
Ryan
Just wondering if there is any truth in the tunnel mount style causing play in the DS? Because of the way the TA Mounts to the crossmember? It sure seemed like it.
I put on a UMI full length TA and Im completely happy with it. No noise or slop and even road noise is much better than stock. Rear tires feel planted. All around 100x better than stock.
While I’m sure all these aftermarket companies make fine components, I did have issues with Spohn. When I started modding my car, I was going to go all Spohn. Their 405XM tunnel mount T/A crossmember was welded way off and would not bolt up to the car. Despite sending them photos, they said my car was out of wack. Comparing another one from them side by side and it was plain how far off it was, it was welded wrong. They never made good on it.
Since then, I’ve been using and recommending UMI. BRM also makes great looking stuff and I wouldn’t hesitate using them.
Adjustable, mounts to stock tranny mount:
Adjustable, mounts to (shown) tunnel brace:
Adjustable, mounts to (shown) tunnel brace, clears big exhaust & LT's:
Adjustable, mounts to (shown) tunnel brace, clears big exhaust & LT's, with D/S loop:
You'll need this one more thing with any aftermarket T/A:
