Pulled my trans, clutch, flywheel, have some clutch and oil/seal questions.
It was time to replace my chattery clutch today, that had never stopped chattering since I installed it. We never had resurfaced the flywheel the first time around, and that was my mistake. I will now get the flywheel resurfaced or just buy a new one if needed. I bought a new clutch disc to install and I figured the disc was worn down, but now I have noticed my pressure plate has a lot of hotspots in it, although it still feels smooth aside for a couple nicks in it.. The flywheel doesn't look too pretty either.
My questions are:
Will this pressure plate still work or would it need to be replaced? I have read you should not resurface a pressure plate.
Where do yall see the main cause of an oil leak. I just recently switched to synthetic and it has been leaking ever since, but I plan to go back to the conventional oil next oil change. But where exactly does it look like my oil is leaking from?
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0124.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0125.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0126.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0127.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0128.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0129.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0130.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0131.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0132.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0133.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0134.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0135.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0136.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0137.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0138.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0139.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0140.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0141.jpg)
My questions are:
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0142.jpg)
^^X2 ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I had a leak from the intake bad fixed it 3 times and got pissed. Took some sandpaper from rough to smooth and sanded both the intake and block in that area to make sure it was as flat as I could get it. havent had a leak from it since.
Thanks for posting that last picture, I think by looking at your thread I now have my question answered. I take it with the shift fork like that you can then slide the trans onto the bellhousing, and then you slide the shift fork over the throwout bearing? I didn't realize you could pull the shift fork back like that, as I'm trying to stick mine back together and have been a little perplexed on how it all goes back together.
Yeah, theres a little pin with 2 small pressure pins that hold the fork into place, pry up those pins and then wiggle/jerk/pull the fork out while pullin on the tranny too. Took us like 20 minutes just to pull the fork back.
Any ideas on the pressure plate, guys?
Well i took my pressure plate and flywheel to get it looked at and the flywheel resurfaced today. We found the pressure plate was dished, it was a little lower towards the inner ring of the pressure plate. and the flywheel was horrible. We discussed cutting a tiny layer off the pressure plate and adjusting some of the straps. We determined one of the straps on the pressure plate was too high causing a high spot in the pressure plate on the top side where all the dark blotches are.
For $75 i got my flywheel and pressure plate resurfaced. I was nervous about getting the plate cut because of what i've read about it, but i was impressed. He said they only cut .007" off the top of the plate, but everything looks great. I installed it today and it feels good, I will just wait and see when it breaks in.
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0143.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0144.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0145.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0146.jpg)
![](http://i211.photobucket.com/albums/bb67/Holodream/Clutch/DSCF0147.jpg)
