? on my 1/4 times
Old Oct 6, 2008 | 04:41 PM
TravisMcGill2000's Avatar
Default ? on my 1/4 times
just wanted to know if my times r where yall think they should be on motor with me mods. 1.762 60ft 8.355@81.89 1/8th 13.153@102.05 b4 the stall ant dr's the car ran 1.90 60ft 8.48@82.69 13.17 @105.49 wat do yall think car weighs 3480 with me in it im 220
Old Oct 6, 2008 | 05:06 PM
BigZee71's Avatar
That doesnt sound too bad to me. What the elevation/ humidity like? Are you still spinning the DR's? With a little higher stall you could be into the 12's easy n/a.
How do you like those 3.73s on the street with that stall? Im planning on going a similar rought.
Old Oct 6, 2008 | 05:12 PM
im not to sure on the elevation but no more than 1500ft and the humidity was like 50 or so temp about 60 deg i love the gears and the stall i just figured i would pick up more its a tci 10 in stall.
Old Oct 6, 2008 | 05:38 PM
anyone else think thats about rite
Old Oct 6, 2008 | 06:05 PM
NorCalLt4's Avatar
were u spraying?
Old Oct 6, 2008 | 06:08 PM
Dave J's Avatar
Well I figure you would be 12.8-12.9 with those mods
the 100 shot times look right where they should be
Old Oct 6, 2008 | 06:12 PM
AChotrod's Avatar
Its running good!
Old Oct 6, 2008 | 06:19 PM
LS1Z28-00's Avatar
i guess thats pretty good for an lt1 i just got mine, the dude i got it from said it ran 9.2@78....... so i didnt buy it for speed just DDing but im taking it to the track soon so we will see. i hope it runs better than 9's in the 1/8th.
Old Oct 6, 2008 | 06:52 PM
Originally Posted by NorCalLt4
were u spraying?
no i run 11.8s on spray thats all motor
Old Oct 6, 2008 | 06:53 PM
would a msd coil help im still running stock coil
Old Oct 6, 2008 | 07:01 PM
LS1Z28-00's Avatar
if you need a coil get a msd one, but i wouldnt do it just as a mod only as a replacement part. unless you get a good deal on one but you will see little track gain.
Old Oct 6, 2008 | 07:16 PM
kinglt-1's Avatar
I would stick with the stock delco stuff other than maybe on the plug wires. I have had a brand new msd coil go bad within month's of install. Put the stock unit back in and it worked flawless.
Old Oct 6, 2008 | 08:14 PM
Armyman2445's Avatar
amen on the delco opti advise. Thats all I ever run. Ive ran Accel, and MSD both worked great but crapped out in a span of 2 months.
On your stall: Do you have a tune? b/c with a 3200 and 3.73's u should at least cut low 1.7 to high 1.6's. On an OBD1 car the computer cant read much higher than a 2800 stall on a factory tune. I used to have a 3600 stall I picked up a little over stock but after I had it tuned it was a different story.
Old Oct 6, 2008 | 10:46 PM
i had a guy adjust my shift points and turn fans off and stuff like that.. i dont know if he did anythind else though. wat esle r they to do when tunin 4 a stall
