4L60E question
Old Oct 6, 2008 | 06:38 PM
93lt1M6z's Avatar
Default 4L60E question
my situation is this. when i picked my 94 z up i blew the trans not long after. the guy i got it from sai dhe had the shift points changed when he got it tuned. at WOT with the old trans is would redline for a while..not shift..then shift. if you let off a hair or so it shifts. under normal loads its shifts fine. then i blew it and put a 700hp rated 4L60E trans in it from a company called tranzparts in florida. i am having the same situation with the new trans. at first i thought the new trans would fix it..but it hasn't...so how possible is it the shift points were tuned wrong and who should i go to to re-do them.
thanks
Old Oct 6, 2008 | 08:21 PM
Armyman2445's Avatar
In my experience with A4 cars. There is no need to move up the shift points if your just a bolt on or small H/C car. The only reason I see to move the shift points up is if your still making power past 6000 and need it to shift higher. I had my shift points set back to factory settings after I experienced the same issue as you are facing. Problem went away, and I gained .4 in the quater.
Old Oct 6, 2008 | 08:35 PM
93lt1M6z's Avatar
who did you use to re-tune it..i want the factory settings back
Old Oct 6, 2008 | 10:29 PM
gatorhead's Avatar
Stall wall......search under that and you will find your answer.
Old Oct 6, 2008 | 10:32 PM
i used Tunercat. But you can use any of the mail order tunes around.
Stall Wall wouldnt be this case b/c it doesnt have a problem getting up to speed just shifting. If it were the stall wall it would start the car out in 3rd gear. And that would be a big issue that you couldnt miss.
Old Oct 7, 2008 | 02:24 AM
jarretthise's Avatar
go to a dyno shop...i would imagine they could do it for you...they should have the right programs
