need advice on buying an LT1
First, I was on the understanding that 94 and up need to flash the ECM so if you were told it had a chip you may want to check into that.
Second, you need that tuned ECM redone. My trans had damn near the same behaviour with kickdown and hanging in gear with no upshift. I got mine redone by a guy on here and now my shifts are 1000x's better.
Hope that helps.
Hope that helps.
