which shocks will handle better Koni or bilstien for 96 impala SS?
I just bought a 1996 LT1 caprice impala SS and it needs the front 2 shock absorbers to be replaced, now i want to buy a whole set of shocks, that means 4 shocks. i want to buy either Koni single adjustable shocks or Bilsteins shocks. which shocks will make my car handles better Koni or Bilstein?
i will also btw buy complete energy suspension polyurethane kit.
thanks
thanks
ok for one im not sure if your there too but go to impalassforum.com they will be more helpful, just because they actually own those cars....not just stop and sigh when they see an ss lol
i was just in the same spot and this is what i decided...
why pay so much more for the adjustable ones when most likley, you will never adjust them. many people end up using the same settings all the time....track or street...
i was debating q1a or konis.... then i went with bilstein and saved enough for the next set of bilsteins i will need..in about two years.
also i had heard of q1a shocks failing after like a year of use.....too expensive to last a year IMHO.
i hope this helps u out. i actually just installed the rear shocks today, along with my adjustable upper and lower control arms.
heres a tip when u do the rear, make up...or buy a U-bolt for the upper shock mount. it will make it ten times easier to change them from now on. (if that made sense)
do you have a 94-96 LT1 caprice impala SS?
My understaning is that while Konis are good in many applications they are not good for this one.
I have a mix of Bilsteins and Monroe Severe Service. Bilsteins are like 7 years old with at least 100K and last I had them disconnected from the axle were still stiff and pressurized.
If you go Bilstein just make sure to older them for a 80s Caprice. They are valved for better handling where the 90s Caprice Bilsteins are valves a bit goofy and floaty. Excuse was police landings as the Bilsteins were an option on police cars.
and are they stiffer than the Bilstein's for 1996 LT1 caprice impala SS?
thanks.
Yeah they boltin just fine. The chassis is little changed from 78-96 so lots of stuff can be used. Yes they are stiffer than the 94-6 shocks.
Biggest fittment issue between 80s and 90s stuff would be the 91-2 cars with skirts and the 91-6 roadmastersand wagons with skirts need a longer rear shock to make room for tire changes. Since you have a Caprice/Impala sedan with rounded wheelwells you have nothing to worry about.
Really it is amazing how many parts can interchange, the front caliper rebuild kit for these cars dates back to applications in the 60s and not just General Motors vehicles.
correct?
