Textralia Question
Old Oct 21, 2008 | 10:29 AM
SS1875's Avatar
Default Textralia Question
Anyone that runs the Textralia OZ700 clutch.....do you have an increased amount of noise coming from the shifter area??
Mine disappears when the clutch peddle is depressed but is extremely noisy at idle. Car shifts fine and makes no noise while driving down the road.
Old Oct 21, 2008 | 10:36 AM
06black6spd's Avatar
Yes I have same clutch and makes noise, sounds like the radio is almost playing during driving and idle but gets quite when u engage it all the way, its normal
Old Oct 21, 2008 | 10:57 AM
SS1875's Avatar
Ok thanks, mine sounds like someone shaking rocks in a can. The install was done by a person with many F-body trans/clutch installs under his belt along with my help so I'm sure it was/is done correctly.
Old Oct 21, 2008 | 11:44 AM
Just remember every time you mod you take away drivability comforts
Old Oct 21, 2008 | 07:36 PM
6']['9's Avatar
mine does it too with the clutch engaged, and i have an exoskel
Old Oct 21, 2008 | 08:05 PM
SS1875's Avatar
Don't have to preach to the choir.....nothing is stock on this car however my Spec Stage 3 wasn't nearly this noisy thus the concern.
Old Oct 22, 2008 | 08:08 AM
PewterScreaminMach's Avatar
Hmm, never noticed before with my OZ700 Z-grip. I'll check it out one of these nights and post up. You're saying it only makes the noise when it's idling in neutral with the clutch engaged?
Old Oct 22, 2008 | 09:24 AM
SS1875's Avatar
Idling in neutral, goes away when clutch is depressed.
Old Oct 22, 2008 | 09:55 AM
I'll check it out, probably tonight.
Old Oct 22, 2008 | 10:07 AM
BlackScreaminMachine's Avatar
Internet Mechanic
No noise, on a stock, well Gm upgraded Hurst.
Old Oct 22, 2008 | 11:46 AM
on2's Avatar
on2
Common problem on any car with any upgraded clutch/flywheel.
Old Oct 25, 2008 | 04:51 PM
SS1875's Avatar
Never had it with my Spec Stage 3.
Old Oct 25, 2008 | 04:53 PM
SS1875's Avatar
Beginning too wonder if it isn't the B&M shifter causing the noise and it's just more noticeable now with the new TEX clutch and my new cam and it's wicked overlap.
