Shifting problem persists; unable to shift quickly.. HELP!!
Here is the catch though, it only happens during the first time you shift into gear with the clutch down... to put it easier:
1) press clutch
2) Engage into gear quickly and get the block
3) DO NOT RELEASE CLUTCH
4) Go into any other gear and its completely smooth, no matter how many times you shift. It will be like a knife slicing through butter going into gears.
5) release clutch
6) press clutch down again and process repeats
If you shift slowly and let the gear "suck" the shifter in and just ease it into gear (2-3 seconds), the gear will engage with no apparent sound, but the block is still there, but after a bit the shifter will just slide into the gear.
Attempts to fix problem:
1) New transmission fluid
2) New GM master
3) Drill mod
4) New Hydraulic fluid
Edit: I have also done the clutch slipping tests.
Revving to 5-6k at a stop with clutch down does not move my car at all.
Hitting the throttle at around 20mph in 4th has a steady increase of rpm/mph, not a wide variation between them.
Invest in a mityvac and see how it is after using that on the system. Other symptoms (which you may be afraid to encounter) would also be clutch sticking at high rpm, or a quick shift at WOT will act like a wall is there.
Bled again, it was still sticking. Got fed up, bought a mityvac and pulled a lot of "trapped" air within the system. Significant amount. Took it for a long drive, then did a few WOT pulls to the top of 5th. Shifted like butter at redline.
I've bench bled the master and left it hanging in the garage overnight, sure enough thanks to the angle I left the system at, air worked its way up the system back into the reservoir. Once air gets in, it is a PAIN to get out. On top of that, it will disperse itself into the fluid and lower the boiling point further creating and trapping gasses from the degraded fluid at each WOT run.
I'm saying if you've exhausted all avenues with hardware, bleeding for air etc, then last point of failure is the clutch itself.
From what it sounds like either a) hole in system, air is getting in, or b) line is touching header and boiling fluid.
I just ordered a mity vac to try and bleed it out. If that doesn't work, I have a brand new slave sitting in my hatch(reluctant to drop the tranny). If that doesn't work either, I guess Im gonna be ordering the LS7 clutch.
I have 47k miles and it happens in all gears, at all speeds, even at idle... how would this be something internal unless I got like the most messed up tranny in an fbody. The mechanic himself told me its either the slave or a clutch.
