T-56 on small block
Given the information detail you've supplied, I can definitely say maybe...
Many variations of T-56's. The most common swap onto a SBC is the LT1 version, and it's well documented. Also depends on you vehicle. A SBC in a 69 camaro would have diff needs than a SBC in an IROC camaro.
You'll need the LS1 bellhousing from a Fbody, a custom flywheel (1pc or 2pc RMS), and utilize the Hyd setup from an LS1 fbody. Would be best to change the shifter cup over from an LT1/LS1 T56, and use any Fbody stock/aftermarket shifter. You'll need to verify the pilot bearing is fully engaged during a mockup.
