Clutch hydro issues...about to give up
Here is the story, i swapped my lt1 for an ls1 and got it up and running this fall. The motor was from a friends car, the trans was from my lt1 car just with the front end swapped over(housing, front cover, input shaft, hydralics)
I bench bled the master(gm one, had a few thousand miles on it) put it in, bought a new slave, hooked it all up and started to bleed by hand. That was not working at all, so i bought a mighty vac and it gave me a firm pedal after just a few pumps.
This is a spec 3 clutch btw
Since i had the flywheel resurfaced i took it super easy for the first 600 or so miles. Once that period was over, i noticed that i could not shift when at a high rpm, i could simply just not pull the stick out of gear.
It also fails the dragging test, by that i mean if in gear with the clutch pushed down, revved to about 5-6k the car lurches foward. I assume that means it is not disengaging all the way. I also assume that is the reason i cant shift at a high rpm, or why it is hard to get into gear sometimes.
I had 0 problems with the trans with the lt1, so i am hoping all the shifting problems are clutch related....
One more thing, this clutch has about 1k on it, and it still grabs RIGHT off the floor. I would figure it would release higher now?
Any thoughts...i did tons of searching....but dont know if i should try a pressure bleed since the vacuum wont get it right, or i should start replacing things that only have 1k on them
Btw, it is shimmed.
Thanks
Tim
Btw, it is shimmed.
Thanks
Tim
If the clutch is shimmed and the pedal is still on the floor I would guess that it is in fact a hydraulic issue. Have you noticed it getting any better after bleeding? Let me know and I will be happy to assist you further. Thanks!
I guess my main concern is why can't i seem to get it to bleed? Am i doing something wrong, are there better methods?
I am trying to track down a motive pressure bleeder to give it one last go.
I know the guys at Tick Performance have an adjustable master that I hear is a badass piece... we offer a new replacement slave with a release bearing for $70.
Hey Tim, I got your PM and I agree that a good pressure-bleed will likely do the trick. It can take some time and effort but it really is the best method for removing air from the system. Please feel free to email of call me if you need to as I will be happy to assist you. Thanks!
I have had issues bleeding these cars in the past and having worked on lots of cars from lots of manufactures I can say with confidence that the GM hydraulic systems are terrible when it comes to removing all the air. It seems like they have a tendency to hide air better than any other.
I actually found out that the lt1 pedal setup i am using does not push the master far enough to fully disengage the clutch. My car is a 97 with a 98 motor.
So i am trying to fab something up till i get new pedals, thanks for all the help.
BTW, the power bleed i did last night made it shift like butter!
