Squeaky Pressure Plate? Need Recommendation
Clutch suddenly quit disengaging. Suspected slave cylinder so I replaced it. Not the problem. Peddle pressure is a little less than normal. Peddle feel is not very smooth during last half of travel.
Now when I depress the clutch, a squeak is coming from clutch area. It sounds like metal-against metal. Almost like a spring is being stretched and rubbing on something. Clutch is a ZOOM model MU70185. 4 years old & 33k miles.
Question 1: Do you think the pressure plate has failed and is causing the squeak?
Question 2: If I replace the clutch, what do you recommend. FYI, I no longer drag race and I pamper the clutch. I don't even accelerate very hard any more. Want something that will hold the power and last a LONG time. Don't want to spend much more the $500. If kit doesn't come with a flywheel, plan to buy a new one from Auto Zone.
Considering: Centerforce Dual Friction or DFX clutch. Hays 85-105. RAM Powergrip or Powergrip HD from Summit
I need your help.
Danny
I need your help.
Danny
I talked to a Technical Support person at ZOOM, the company who made the clutch that appears to have failed. He said it sounded like the self-adjusting mechanism failed and said that the only way to know for sure was to remove the clutch. I have been kicking myself for not removing the bell housing and looking at the clutch when I replaced the slave but now I know it wouldn't have helped me diagnose *that* problem.
Regarding Question #2, I would appreciate any comments (pro or con) you have on clutch brands and models.
Danny
Danny
