Monster Adjustable Slave Cylinder
The slave cylinder is not what's adjustable, the master cylinder is.
Tick offers an adjustable master cylinder that is far superior to the stock unit and will allow for adjustability to tailor the pedal feel to what you want. While our clutches do not require this, the Tick unit if by far better than the oem.
"will allow for adjustability to tailor the pedal feel to what you want. While our clutches do not require this."
Thank You
Our clutches engage at the stock point, some guys like to have the engagement lower and some like it higher... with the adjustable master you can change the engagement point. Ours is designed for the stock engagement and stock hydraulics but will work with adjustable units.
The benefit of the Tick Performance unit is that it is a far superior part versus the stock unit... there really isn't a comparison.
