couple t56 realted questions
my tranny mount bolt holes got stripped out. i guess i used the wrong bolts and when i tried to torque them down they stripped.
so im going to helicoil them and get noe bolts. but im not sure what the oem bolt size is. if you know the threads and the length of the bolt that would be great.
also im trying to solve some engagement issues with my lt1 clutch. ive come to the conclusion that i need a flywheel shim. but i dont know how much the flywheel has been machined. so i need to know the oem thickness of an lt1 flywheel and also the minimum thickness would be helpful as well.
thanks in advance
-mark
thanks in advance
-mark
The bolt holes are 10mm x 1.5 thread pitch. Theyre the same as the bolts that hold the tranny to the bellhousing.
I've got an LT1 flywheel so I can take a measuremnt off of it and let you know tomorrow.
Jason
Jason
that would be greatly appreciated. but it will only help me if its a flywheel that has never been tunred
thanks for the bolt sizes. now i can get my helicoil
