mild vibration and nosie when in neutral or with clutch in...
my T56 got a new clutch put in when i bought it (free labor and included warranty).
it is dual friction kevlar (custom built by a reputable clutch builder in tampa).
i have a mild "chattering" noise in neutral and thus mild vibrations.
is there a potential problem there or is that normal.
btw. what is the definition of clutch chatter?
everything balanced and flywheel resurfaced.
it is nothing bad, i probably overexaggerated it a little.
its perfectly fine in gear though. no issues. and it is totally broken in.
Since it's balance & broken in, then I'd say it's just the disks kissing either the flywheel or the pressure plate when in neural or w/ the clutch pressed in. Mine has done the same thing from time to time.
thanks for the help and reassurance.
