LSX clutch options? nv4500 tranny
this is a little off topic being that this clutch is for a truck, but my research tells me that any lsx clutch should work on a lq4. now my dilema is that i know my nv4500 5 speed has a 10 spline input shaft. lets sat for instance i get an ls7 kit, it should bolt up correct? but has the wrong spline count, any chance on getting a different disc for an lsx clutch? can anybody shine some light on the clutch options and any help with the nv4500 setup would be nice. im just replacing a stock clutch, i smoked it pretty good and it just doesnt feel the same, its probably still ok but im not a fan of being stranded when it decides its had enough.
The NV4500 does in fact have a 10 spline input shaft . As far as getting a disc made that is the correct diameter with a 10 spline hub is not an issue at all . I have them built all the time for customers doing conversions .
pedal feel is perfect, it just grabs at a different spot than previous i believe. feels great and doesnt slip, but catches at a different point, i know smoking it took some life off of it, i guess i will have to find a spec and gbet under therer and measure the friction disk
smoking clutch? maybe needs driver mod
