clunks while engaging and disengaging clutch..ideas??`
Who else has this problem when your shifting your lower gears and something begins to clunk and also causes excessive chatter?? Mine happens when im going in and out of first or coasting in second and shifting into another gear. Anyone else have that problem or found a solution or have any ideas what the hell it could be??
Something clunks in mine when crusing in a parking lot in 1st for example, and I push down the clutch really fast. Almost like a "buckling" kind of feeling.
EDIT: I was thinking it might be the slack in the 10bolt, does anyone with a 12bolt or 9' experience this?
Is the noise coming directly under you where the tranny is? or is the noise coming from the rear end of the car? I recently experienced that same kind of noise and it was a broken tranny mount.
ive got a new tranny mount in there. are u all still running the stock driveshaft and stock master cylinder? The noise is coming from around the tranny i think. I dont understand how it could be the clutch if it just grabs and releases? it doesnt sound like its a noise caused by spinning as the flywheel and disk could..it does sound like it may be the pressure plate though...what clutch is everyone running?? ive got the ram powergrip hd.
Kleeborp the Moderator™
Powergrip HD here, same thing.
This thread, meet this thread:
https://ls1tech.com/forums/manual-transmission/433628-my-clutch-making-klunking-noise.html
most of clunk noise is from rear end, the rear end gear need a little play otherwise the gear will heat up very fast. while you accelarate in 1st then press down clutch, cause the drive line unload to making the noise.
also there will be very little play inside the tranny too!!!
Originally Posted by MeentSS02
No it won't...
can all of you answer the following questions to see if there is a common part??
1. clutch
2.flywheel
3.DS
4.tranny mount
5. rearend
6. stock or upgraded master/slave cylinders
7. torque arm
this is to see in what area we're having the issues.
1. clutch
2.flywheel
3.DS
4.tranny mount
5. rearend
7. torque arm
heres mine
1. ram powergrip HD
2.billet flywheel
3stock DS
4.prothane tranny mount
5.stock rear with 3.42's
6.stock 99 master cylinder and 01-02 slave
7. spohn non tranny mounted TA
1. ram powergrip HD
2.billet flywheel
3stock DS
my clutch is rather new. just a few months and not even 1k yet. I see your running a spec, so that eliminates it to being ram specific. Anyone think it could be the hydraulics..the master or slave cylinders?? maybe low on fluid? im just guessing here judging on the type of sound and how it related to the rest of the moving parts and how they funtion.
1. clutch
2.flywheel
3.DS
4.tranny mount
5. rearend
7. torque arm
1. clutch
2.flywheel
3.DS
4.tranny mount
5. rearend
7. torque arm
1. Ram Powergrip (dual friction disk)
2. RAM billet steel (new when installed with clutch)
3. Stocker aluminum (3")
4. Prothane, no metal plate installed
5. Stocker 10-bolt, bolt in relocation brackets for LCAs (torque checked to no avail)
6. Stock hydraulics, no drill mod, new stock slave installed with clutch
7. I've used both the stock TA, and an LG torque arm, no difference. LG did feel a bit more solid though.
I'm leaning toward a combo of the clutch (it has been in there for 20k miles) and rear end slop.
our mods are similar, but bigdsz is running a spec, not a ram. id consider the clutch if i had more miles on it. im starting to think the hydraulics may be the culprit as well as the rearend slop. i may just replace my master and slave cylinders to see if that is indeed it..unless someone beats me to it.
