Clutch recommendations requested
I'm replacing the stock T56 (2.66 1st gear) in my stock 99 Z28 with a replacement T56 from Tremec with the 2.97 1st gear. This car is a daily driver and I'm just looking for a reliable stock replacement. Should I go with GM, Zoom, Hays, Centerforce, or is a Pep Boys replacement good enough?
I found that Pace Performance sells the LS6 clutch disc, pressure plate, and flywheel assembly for $460. Sounds like a pretty good deal considering I plan on installing ported heads, LS6 intake, Pacesetter headers, and a moderate cam in the future.
if its stock id hav to say that pep boys would be good the hav a lifetime warranty and the one in my car now is from them it was in the car wen i bought it its last 30k very very abused miles
Just one recommendation for Centerforce? No other opinions from anybody? I haven't seen very many good reviews for Centerforce on this message board, but that was for higher performance clutches.
exedy seems good but what kind of power are you looking to put down? and how much do you want to spend there are some good clutches and if you plan on adding a good bit of power with that cam you will need something a little better then a ls6 clutch. try monster clutches
I would also look into buying a Tick Master Adjustable Cylinder. All of this should give you a pretty nice shift which will hold around 400-450rwhp, while keeping a stock pedal feel.
Ill second the reccomendation for monster clutches. Im running a centerforce 12 inch And its good, but what you get for the money with Monster is unbeatable! And a 12 month warranty? Seriously a good freakin deal. Hell a sintered Iorn disk clutch for 700ish bucks, works for me!
381408, boys, centerforce, clutch, clutches, gm, good, kit, ls1, pep, performance, recommendation, recommendations, replacement, zoom
