Help... Just did clutch install, clutch fluid everywhere
Thanks for any replies. I just installed a Spec 3+ with all the bearings, new slave and remote bleeder. Got trans and everything in....Went to bleed clutch and kept getting air bubbles. Finally looked under car I have clutch fluid everywhere. On the starter, firewall, dripping down bellhousing. First of all, what do you think caused this? 2nd, is this bad for the clutch or flywheel if the fluid got on them?
Thanks,
Troy
Thanks,
Troy
Thanks,
Troy
Thanks,
Troy
