clutch fluid
Old Dec 9, 2008 | 01:19 PM
McNair06Goat's Avatar
Default clutch fluid
Looking to find the best clutch fluid to run with a high hp app. and what has the highest boiling point
Old Dec 12, 2008 | 06:29 PM
TDP's Avatar
TDP
I use Valvoline Synthetic DOT 3/4 in all the cars that go thru my shop. Never had any complaints about it. I believe the boiling point is 430* range.
Old Dec 12, 2008 | 08:34 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Same here, thats what I use with great success!
Old Dec 12, 2008 | 09:19 PM
ZMONSTER!'s Avatar
Neo super dot 610 (~600 degrees dry/421 degrees wet) Motul rbf 600 (~600 dry/420 wet) and the best is castrol SRF (dosent boil, like ever)
Old Dec 12, 2008 | 09:23 PM
Engine_HP's Avatar
i use the brake fluid (21) DOT 3
Old Dec 12, 2008 | 09:35 PM
03 BUSA's Avatar
I heard that SRF is like $80, but yes it is the best, used in all our Cup cars.
Old Dec 12, 2008 | 09:40 PM
ZMONSTER!'s Avatar
Oh ya its expensive as hell, thats why I went with the motul
LANDONZ's Avatar
i may be a idiot, but what do you mean clutch fluid? How do i check mine?
Old Dec 12, 2008 | 09:53 PM
ZMONSTER!'s Avatar
do you know where the resivoir is? If so remove cap and see if the fluid is black.
Old Dec 12, 2008 | 10:55 PM
LANDONZ's Avatar
yes, its behind or beside the brake booster? what do I add if needed?
Old Dec 12, 2008 | 10:58 PM
ZMONSTER!'s Avatar
well you look at it and if its blacker than satans heart you need to flush and replace the fluid. not a lot of fun.
Old Dec 12, 2008 | 11:20 PM
Wesmanw02's Avatar
Not fun, but not hard either.
Basically you just fill the master with fresh DOT 3/4 fluid, push the clutch to the floor, open the bleeder, let the old fluid squirt out, close the bleeder, pull the pedal back up, and repeat.
When you have clean, fresh fluid spraying out of the bleeder, top the master off to the specified level, put the cap on, and you're done
Old Dec 12, 2008 | 11:37 PM
ZMONSTER!'s Avatar
a lot easier with a buddy and a speed bleeder. You could also try sucking the fluid out of the reservoir with a 'turkey baster' type object, fill it with the new fluid and then pump the clutch a few dozen times, suck out the bad fluid, replace and repeat until the fluid is clear after pushing on the clutch. It worked for a while for me but apparently has worked better for some others.
Old Dec 13, 2008 | 07:05 AM
hymey's Avatar
Silicon based ester fluids ie dot 5 are compressible to a certain degree to improve and maintain good brake pedal feel in racing applications. Non compressible fluids are glycol based they absorb water more readily but more suitable for clutch applications as they don't compress like silicon based fluids. Unless you have SRF which has its own patented chemical structure and is the only real non compressible dot 5 fluid on the market. I would go full synthetic dot 3 or 4 or one better dot 5.1 which is basically a more refined dot 4 with a very high boiling point and zero compressibility. Good choice Motul dot 5.1. Great fluid very good quality and high boiling point which will reduce pedal sticking and grinding gears due to zero compressibility and high boiling point. It is relatively cheap still dearer then supermarket brand but well worth it. I change my fluid at every oil change. A bit overkill but I bled mine properly then use the ranger method with syringe so I go through very little fluid and always have zero pedal issues and keeps seals in good shape.
Old Dec 13, 2008 | 11:06 AM
thanks sounds great, also where is the best place to get a slave cyl.
Old Dec 13, 2008 | 03:57 PM
ZMONSTER!'s Avatar
are you swapping out your clutch?
as far as slaves go summit sells them.
Old Dec 13, 2008 | 08:00 PM
Wesmanw02's Avatar
RPM Speed has the 01-02 GM Slave (improved design) for about $130.
