LS2 Remote Bleeder
Ok guys I know a lot of you have been waiting a long time for this![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
We will be having a LS2 remote bleeder available very soon.
We searched high and low for the proper fitting for the LS2 slave and never found one so we contracted with a fitting company to manufacture the fitting we needed.
They sent me the first two samples of the fitting and I'm putting pictures on here of the setup. It will be a few weeks before we will have the first shipment of the fittings to make them up.
Now the down side
It's costing us $15 each to have the fittings manufactured at this time. So the cost of the LS2 remote bleeder will be $90 but anyone that has tried bleeding their clutch will know it's still well worth it.
And the other issue
Since GM decided to place the bleeder right next to the supply line you will have to do one small mod to install the remote bleeder. It is a very easy mod. You just have to file away a little bit off the supply line boss to make room for the fitting and sealing washer. I'm also posting pictures of this mod. It took me like 5 mins. with a file to do it.
![](http://inlinethumb07.webshots.com/41990/2079728380044714518S500x500Q85.jpg)
![](http://inlinethumb13.webshots.com/10188/2714181030044714518S500x500Q85.jpg)
Now the down side
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
And the other issue
![](http://inlinethumb22.webshots.com/41749/2443979140044714518S500x500Q85.jpg)
