2002 6 speed problems
Old Dec 12, 2008 | 07:18 PM
bigtim02ta's Avatar
Default 2002 6 speed problems
i have been having trouble with my o2 ta tranny 6 speed when i go into reverse it wont let me go in sometimes and sometimes it grinds or pops out what could it be and what do i have to buy to fix it.
Old Dec 12, 2008 | 08:30 PM
thesource's Avatar
Does it go into 1st ok with the engine running ?
Old Dec 12, 2008 | 08:33 PM
BlackScreaminMachine's Avatar
Internet Mechanic
mmmmhm sound like broken.
Old Dec 13, 2008 | 12:19 PM
RevGTO's Avatar
Pontiacerator
Read this thread: https://ls1tech.com/forums/manual-tr...t-reverse.html
Old Jan 1, 2009 | 12:34 AM
bigtim02ta's Avatar
well i have a fairly new spec3 clutch about 25k on it lol but my clutch squeals bad taking off in first most of the time but doesnt in any other gears i have lugged it trying to get it to slip i am going to change the fluid see if that helps how many quarts do they hold.
Old Jan 1, 2009 | 09:05 AM
camaro_five0's Avatar
Maybe the syncros are misaligned? Try putting it into 2nd or 4th and then reverse.
Old Jan 1, 2009 | 03:09 PM
RevGTO's Avatar
Pontiacerator
Originally Posted by thesource
I would definately make sure its going all the way into gear first . You can usually check this by turning the engine off and putting it into reverse . Start the car up and let off the clutch . If it pops out , you have an issue with the trans . If it does not then you have an issue with the clutch .
Did you perform this test?
Old Jan 3, 2009 | 12:38 AM
bigtim02ta's Avatar
i have not tried it yet i will in the morning and let u know does it have to be warmed up?
Old Jan 3, 2009 | 12:50 PM
BlkZ28559's Avatar
You cannot put it in reverse when the car is off.
Old Jan 3, 2009 | 12:54 PM
BlkZ28559's Avatar
Check out the sticky on the clutch pedal.
I would start with the fluid mine was doing the same except not popping out of gear. I bled my clutch a few times it goes in fine now but I,m pretty sure my hydralics need to be replaced.
Old Jan 3, 2009 | 02:42 PM
bigtim02ta's Avatar
well it does pop out when i turn it off and put it in reverse
Old Jan 3, 2009 | 11:17 PM
RevGTO's Avatar
Pontiacerator
You'll have to pull the tranny and open it up and inspect the reverse gearset, slider, fork, etc. My friend had the same issue and it was pretty messed up in there.
I wouldn't delay too long either. The longer he waited and the more he drove it, the worse it got. I think he was continuing to damage parts.
