G.T.O t-56 swap
G.T.O t-56 swap
What would be the "weak link" in this trans?I am putting it behind a 496 inch motor and want to spend my hard earned money wisely.Viper output?It seems everyone has a different opinion.Any trans savy guys have any input?The trans has 800 miles on it.
Really depends on how you'll use it.. The output shaft should only be a problem with very heavy cars, or those doing high-hp clutch dumps on slicks. The tight ratio might be an inconvenience on the high-hp motor, unless you're putting it into a heavy car.
Is the "800 miles" new from the factory, or after a rebuild? The most common failures from stock are synchro keys and fork pads after some hard passes.
Thanks
It is going in a all steel camaro.Was going to be a race car but I've had the thing so long my taste has changed.Now I want a nice reliable big block car that I can drive places.No big slicks or 6000 rpm clutch drops.I am running 255-60-15 street tires.I pulled the roller cam and big carb and am running a cam that makes 500 H.P.The trans was new not rebuilt(out of a wreck).If you think it will live behind this motor,I will leave it alone.It will see the track once or twice a year.Thanks for all the input.
