I need some T56 measurements!!!
I need a couple of measurements to see if my wacky idea is going to work. If someone has an LS1 T56 with a stock bellhousing laying around, I would really appreciate a few minutes of your time.
Here are the measurements I need:
1. From the end of the input shaft to the block mounting surface of the bellhousing (this is essentially how far the input shaft sticks out past the bellhousing): 24mm
2. This one really doesn't require a T56 at all. On an LSx engine, with the flywheel and clutch bolted up, I need the measurement from the surface on the block where the bellhousing bolts to to the fingers on the clutch pressure plate: ???
If anyone can help with these, I would be most appreciative.
Thanks,
Matt
Thanks,
Matt
