Place to buy just clutch disc
I recently purchased a t56 conversion and am currently installing it. The clutch disc that came with the tranny was cracked but the pressure plate still looked practically new. The machine shop I took it to told me I'd be fine just replacing the clutch disc. It seems as though everyone sells the clutch kits but little to no selection for just a disc. Just curious where you guys think I should look. Its for a 94 z lt1, with around 400hp/400tq, with DR's. thanks
If it is 11" 1and1/8 26 spline,hays part#490-40-221 should do the trick.It is a strip/street disc and costs 99 bucks at jegs.Jegs phone#1-800-345-4545.Good luck with your swap,Ernie
