Shifting issue still not solved...
Tick Master
LS7 clutch
New Slave
But, a problem still persists.... there is still a slight block or slight grinding going into the gears when shifting very quick. Sitting at idle and shifting quick will either get you a block or grind for very little. Heres the thing though, if I hold the clutch pedal down for 3-5 seconds and then shift, the shifting is perfectly smooth, no grinding or block whatsoever, goes in as quick as you shift it. I'm gonna try bleeding it some more and see if that helps, anybody else have any ideas?
I also do hear some slight clunk/thump when going into a gear from neutral. Tonight while sitting at idle in my parking spot, I also realized if I press in the clutch I do hear some sort of clanging/clunking sound coming for the transmission area for 1second or so.
Tick Master
LS7 clutch
New Slave
I would make sure that you have regular Dex III fluid in the tranny first. We've had some problems with the Mobil 1 stuff here lately. If that has nothing to do with it, and adjusting the master doesn't help it may just be time to have the transmission itself gone through.
I last filled up with Mobile 1. Could tranny fluid cause this?
Another thing, if I have the mityvac hooked up into the reservior with lets say 12psi, should the pressure drop down by itself without doing anything? I can see the pressure gauge slowly dropping on the mityvac.
I have had two LS1 cars, both since new and neither one could I just cram into gear and easily row through all 6 gears when sitting there without feeling some sort or gate or restriction. They always go into 1st easy but trying to just shift through the gears completely notch free? I don't think so. They need to be spinning inside to some degree to line the synchros up to allow the shift.
If I were you, I would be more concerned with how it shifts when going down the road and WOT.....matching wheel speed/rpms and see how it does. If you get a grind or blockage problem when shifting then, well I would say synchros are toast. No reason to be shifting through all the gears when sitting still anyway.
I think my system has a leak somewhere, I believe my car is driving worse and worse as the days go on leading me to believing I keep getting air in my system some way or another. The first night I was able to bang into second with relative easy(not perfect though, but the best I was ever able to) then into third. As the days go on, going into second gives me a bigger and bigger block. Whats the best way to check a leak, and a leak would probably explain me losing mity vac pressure, right?
I bet running the shitty GM hydraulics for so long tore up the synchros.
I believe, and really hope, my problem is hydraulic related.
Your problem is a lot worse than mine too. I can go into all gears, its just if I go into them fast it stops me. If I ease the shifter into gear all is fine; but this is in no way fast or comfortable at times.
To answer your question about the mitivac.....the pressure can bleed off due to a leak in the little catch cup.....try blocking the end of the line with you finger and build up some pressure and see if pressure drops...
Did you try extending the master cylinder rod to disengage the clutch some more?
If I do have a leak, where would be the best places to check for it?
