LS3 + TKO500 = What clutch and flywheel??
I had 350 + TKO500 and now moved to LS3 crate. I have allready adapter bellhousing from Tremec but now i need info what flywheel and clutch should i use. Can stock LS3 vette flywheel to be used ?
I used a Richmond 6spd with an L92. As far as the flywheel and transmission fitment it will be the same as your LS3/TKO combo.
Andrew
This would be the bellhousing that I would use:
https://www.holley.com/products/driv.../parts/LK4200K
Andrew
Thanks for the quick reply. I just recently started to build my 73 back up. I let it sit for about 10 years and now I am thinking of putting in a LS3. Honestly I don't know where to start. Currently, I have my SB 350 mated up to the Tremec TKO500. Did you say you had a build thread on what you did to mate up the LS to the TKO?
https://www.holley.com/platform/chev...ngine/ls-swap/
Here is link to where I mated a Richmond 6 speed to a LS. A TKO500 will bolt up exactly the same way.
https://ls1tech.com/forums/conversio...ion-2-0-a.html
Andrew
