Wiring questions A4 to M6 Swap
I completed a A4 to M6 swap on my car except for wiring reverse lock out and CAGS. I know that reverse lock out goes in red pin #44. I am a noob and dont know which spot is #44 on the pcm. Also where does the CAGS wire go to , I dont want any codes on the PCM once i flash it to m6. Thanks!
First of all get rid of that CAGS **** while you are there..don't even worry about it, that is useless..lol
The #44 is the Red PCM Connector, take it apart and find Pin 44. You may have to take one of the Wires from the Auto setup and move it over to there. I suggest moving the one that is in spot 42 and move it over to 44. 42 is for the Auto Torque Convertor Lockup Clutch, so you won't need that with the T56.
I had my Harness completely stripped down when I did my Swap.
Here is my thread if you want to look at it..
MY T56 SWAP
MY T56 SWAP
