HELP! ls1 to T101 adaptor????
Old 01-20-2009, 04:37 PM
techtrix's Avatar
Default HELP! ls1 to T101 adaptor????
I just bought a T101 4 speed, straight cut geared dog box for my LS6 powered RX7. The shop i bought the tranny from sold me a used quartermaster bellhousing from an older style chevy motor. bolt pattern will work -1 bolt, but the bellhousings inside is smaller, and it wont go around my flywheel (im not changing my exedy twin disk flywheel/clutch setup).
is there a bellhousing that will fit an ls1 to a t101, or an adaptor plate that will bolt onto the back of a t56 bellhousing to allow a t101 to bolt up?
Thanks!
Michael
Old 01-22-2009, 08:40 PM
techtrix's Avatar
found what i was looking for...
Old 01-28-2009, 08:00 PM
Fahrenschnell's Avatar
What did you find....I may be doing this soon.
Old 01-28-2009, 09:49 PM
Project GatTagO's Avatar
Received 1,438 Likes on 908 Posts
Look in my build thread. The link is in my sig. A T101 will fit just like my Richmond 6spd.
Andrew
Old 11-11-2009, 03:39 PM
Andrew R's Avatar
I know this thread is old -but I was searching T101 trans on the site and figured I'd put at least one solution for other people that actually use the search feature.
Quicktime makes one...
http://www.quicktimeinc.com/products.html
so does pace performance -but you have to change your flywheel:
http://paceperformance.com/index.asp...&ProdID=228851
Old 11-11-2009, 05:12 PM
The T101 does not require a special flywheel. Flywheels don't care what transmission is being used as long as the clutch disk splines match the splines on the input shaft of the transmission.
Andrew
Old 02-19-2010, 04:39 PM
gmullin's Avatar
Andrew
if the bolt patern for that specific clutch dosent line up with your flywheel u will need to use their flywheel
Old 10-01-2011, 10:37 AM
Jeff Smith's Avatar
found this one I was looking..I think about buying t101 for my camaro Ls2
Quick Reply: HELP! ls1 to T101 adaptor????
