Syncro?
Old Oct 5, 2003 | 04:48 PM
vegasta's Avatar
Default Syncro?
How does one know their syncros are going out? Will it be replaced under warranty if you have an aftermarket shifter? When i go from 1-2 it seems harder like almost it gets caught on something. Then it goes into gear kinda annoying, does not happen from 2-3 or any other gear.
Thanks
Old Oct 6, 2003 | 01:35 PM
Murdock's Avatar
Default Re: Syncro?
I just had new syncros put in. My gears were acting the way that you described. Can you put the stock shifter back on before you take it to the dealer?
Old Oct 6, 2003 | 05:50 PM
vegasta's Avatar
Default Re: Syncro?
I am not too confortable removing the shifter maybe a shop would do it.. I dont mind paying for upgraded syncros. Is there a place where I can buy like upgraded syncros and upgraded shift forks?
Old Oct 7, 2003 | 11:47 AM
xny89's Avatar
Default Re: Syncro?
I just picked up a 99 z28 with a 6-speed. I had a similar problem - shifting from 1-2 with engine revving above 4000 rpm would cause the gears to grind. I brought it back to the dealer, under warranty and was told that the computer software had to be upgraded - and it worked. Hope this may be what you have.
Old Oct 7, 2003 | 12:11 PM
66ImpalaLT1's Avatar
Default Re: Syncro?
Placebo, the computer has no connection to the clutch or transmission outside of CAGS.
