Clutch pedal spring broke?
Tonight I was moving my car and pushed the clutch pedal in and I heard a ting/snap sound. I got out of the car, look on my floor mat and saw what looks like a part of a spring.
It's about one inch long, curved one end and the other end has grease on it.
The clutch pedal goes in and out fine, should I worry?
I thought I heard of something like this a year or so ago on the net but can't remember what it was?
Any idea's?
Any idea's?
Re: Clutch pedal spring broke?
Yeah, mine broke too, but stayed on the pedal. One end just snapped. I took it to the dealer and they ordered the part. I've been driving without it (since I haven't felt like going to the dealer) for quite a while and been ok, but I think it's best to get it replaced if you can. Instead of relying on the spring to help return the clutch pedal, you're relying soley on the hydrolics. I heard they have a new spring that is stronger to fix this common problem, but I'm not definitely sure on that.
Chris
Chris
mine broke as well and it has been many many miles since then with no issue. What sucked is mine broke during a race so it kinda scared me which is another reason why I didn't want another one on it. These things are notorious for breaking.
I broke 3 of them when I had a stock clutch.The dealer replaced 2 of them and the 3rd they said enough is enough.I drove and raced for about 3000 miles without the spring
Thanks
I didnt even know i was suppose to have one. Whats it called; clutch pedal spring? Should only be a couple bucks right?
Tom
Tom
Will the dealer replace mine as I have the same problem. But I have a pro 5.0 shifter and Longtube headers?
Long tube Headers
Hooker Cat-back with cutout
Lid, MAF, programming
Pro 5.0, Poly Trans mount
Moser 12 bolt with 4.10's, 3.5" driveshaft
And a bunch of other suspension/appearance mods.
They ordered the spring and will be installing it under warranty as soon as it comes in.
So yes, they should warranty you just fine .
Chris
