Change Tranny Fluid in a M6
Old 10-07-2003 | 06:36 PM
vegasta's Avatar
Default Change Tranny Fluid in a M6
Is there a link someone can post on how to change the transmission fluid in a M6 ?
Thanks
Old 10-07-2003 | 11:59 PM
991LE's Avatar
Default Re: Change Tranny Fluid in a M6
It is pretty simple.
There is a drain plug and a fill plug
Remove the drain plug and drain the fluid into an appropriate receptacle.
Install the drain plug and torque it to20 ft/lb
Remove the fill plug and add Dextron III until the level is at the bottom of the fill plug. Takes about 4 quarts to fill.
Install the fill plug and torque it to 20 ft/lb
Old 10-08-2003 | 06:39 AM
Mike K.'s Avatar
also use one of those pump things so you can get the fluid from the bottle on the ground to the opening on the top.
Old 10-08-2003 | 05:14 PM
vegasta's Avatar
Could you tell me the location of the drain and the fill plugs. If I do not have a torque wrench can i still do it with a bit of muscle. Also What size do i need to open thise. And also do I need to use locktite or no when putting the bolts back in?
Thank you
Old 10-08-2003 | 06:53 PM
Mustang Hat'r 2's Avatar
The drain and fill plugs are both 3/8 just stick an exstension in there or a 3/8 rachet. The drain plug is on the Pass side rear of the trans, the fill plug is on the Driver side more toward the middle and about half way up the trans. If you dont have a pump you can remove the shifter and fill from there but you will need some RTV to reseal it. I use some thread seal on the drain and fill plug and get them tight never torqued them you dont have to get them crazy tight.
Old 10-08-2003 | 10:10 PM
991LE's Avatar
Check out this link
http://www.ls1.com/link_cags.html
There are some pretty good pics of the fill plug. The drain plug looks the same, but is on the other side. If you look close, you can see that the FILL plug has the word FILL beside it. The drain plug has the DRAIN beside it if I remember correctly.
Old 10-09-2003 | 03:00 AM
vegasta's Avatar
Great experiment starts tomorrow ;-) If not time to call the local shop heh
