Soft clutch pedal
Soft clutch pedal
Well I finally got the clutch and flywheel situation figured out. But now I have a new problem... Just put a new slave in with the new ls6 clutch assembly and the car drives fine. I can go into every gear, reverse is a little hard and sometimes first can be a lil tougher than it used to. I have tried to search and since it's not working I thought I would try this.
But the clutch releases very low on the pedal, right off the floor and the pedal is very soft. I didn't put in a new master but is that the likely culprit? Thanks for helping guys
BTW I did just have the flywheel resurface... not that that has anything to do with it but just for info
Daniel
Daniel
