T56 in Third Gen Info??
I did this a few years ago in my 92 Firebird. I used the lt1 flywheel, clutch and pressure plate. Since it was an lt1 m6, I also used the lt1 master and slave. My car had been a 5 speed, but you have to cut the shifter hole back about 2 inches more. It was real easy to fit. I used an aftermarket crossmember that was a real POS, but I am sure there are other options by now.
You can also keep your T5 M/S and bell if you want to put an adaptor plate on the front of an LS1 T56.
You'll find lots of info/FAQs on this swap on TGO
