Clunk comeing from tranny/clutch.
When ever I'm at a curtain RPM, usually around 2000 and I put the clutch in fast it mast a clunk noise. Will do it in
first and 2nd. I think it might be the throw out bearing. Just replaced the clutch disk, pressure plate, flywheel,
throwout bearing, slave cylinder, and master cylinder because I wanted to be problem free for at least a year. It's
got an LS7 clutch, i've only put maybe 1500 miles at the most on it probly closer to 1000. I don't hot rod it...You
think it's the throw out? Or maybe the slave needs the drill mod? BTW a sponsor on here did the clutch job. I
havn't said anything to them yet, wanted to get some opinions before I say something to them about it.
