Should I get a lightweight flywheel
Old 02-18-2009, 01:45 AM
96Formula6spd's Avatar
LS1Tech 10 Year
Default Should I get a lightweight flywheel
Hey guys I am going to be replacing the clutch in my car should I get the money together and buy a lightweight flywheel? Its for a lt-1 car and I am looking at this flywheel
http://fatboy-garage-inc.amazonwebst...source=froogle
Old 02-18-2009, 07:11 AM
davidws6's Avatar
Default Alum Flywheel
If you are going to mainly drive it on the street, I'd say no. You need the inertia of the flywheel to get the car moving.
I had an alum flywheel behind my 402. Really had to rev the engine up to get the car to move. After warping the flywheel faceplate and press plate, I had the stock flywheel zero balanced (stock and had never been checked) and reinstalled it. Been fine since and it takes off like stock with a Spec 3.
I used a 18lb steel behind my 454 and wish I would have stayed stock. But with the extra cubes, it's not too bad.
With a stock cam, should be less noticeable.
Old 02-18-2009, 08:00 AM
Razor_back's Avatar
I agree. I just changed from an aluminum flywheel setup and went to an LS7 clutch, PP & FW. It's soooo much easier to drive around town and to be honest, I don't notice the drop in horsepower (if any). The quick revs was nice, but I'll trade it for the driveability anyday.
Old 02-18-2009, 09:53 AM
merlinn's Avatar
I would say no. I have driven both and I prefer the billet or heavier flywheel. Its easier to drive and the rpms dont drop as much, between shifts.
Old 02-18-2009, 01:54 PM
LS1Tech 10 Year
alright than it looks like ill keep the old flywheel and get it resurfaced since the car is a dd
Old 02-18-2009, 02:48 PM
Grimes's Avatar
my friend did not like the Al flywheel on the street either....
Old 02-18-2009, 03:55 PM
Clevite Kid's Avatar
If you go with the LS7 clutch, which would be great at your power level, it is a heavy pressure plate and disc, so the lightweight Fidanza aluminum flywheel, part no. 198171, would be a good choice to go with the LS7.
You can put this combination right into your F-body, no sweat.
Old 02-18-2009, 04:30 PM
camar0corey's Avatar
I like my SLP billet steel flywheel, I'm not sure if you can get them anymore though.
Old 03-03-2009, 04:13 PM
Cliffo117's Avatar
I felt a huge loss in power going from fidanza to the steel one. I tested it against a few of my buddys car and with the light flywheel i would put about a half car a gear easy and when i switched we were dead even
Quick Reply: Should I get a lightweight flywheel
