Clutch pedal assembly questions
Old 02-27-2009, 11:02 AM
Haans249's Avatar
Default Clutch pedal assembly questions
I was under my dash yesterday taking out my stock MC to replace it with the new Tick unit. While I was under there I noticed two things. First, on my gas pedal is there a spring that is supposed to be on that crossbar that is halfway up the pedal, at the pivot point?
Secondly, on the clutch pedal, at the very top of it, there is a knotch with a white plastic bushing, and on a bracket on both sides there are also some white bushings, is there supposed to be something connected between these items as well?
I looked in the 93-02 service parts catalog and couldn't really see anything since the picture was too blurry. If there are supposed to be parts there, anyone with part numbers? I'm assuming they're some sort of springs. Any pictures?
Thanks
Old 03-01-2009, 07:19 PM
Haans249's Avatar
I also would like to know if anyone has had any problems using stock flywheel bolts. I would like to use ARP flywheel bolts, but they are just too damn flat, and I don't want to risk rounding them off trying to install them on my textralia flywheel as they sink down too far.
Any help would be appreciated. Thanks.
Old 03-02-2009, 10:13 AM
Haans249's Avatar
Someone want to chime in?
Old 03-02-2009, 09:19 PM
Haans249's Avatar
Can ANYONE take a gander at their gas pedal?! Is there a spring on the pivot?!
Old 03-03-2009, 09:44 AM
'00Formula's Avatar
The gas pedal does not have a spring, it just floats on the pivot. And as for the clutch pedal it sounds like you are describing the area for the return spring. And I can't answer about the bolts, as I have never installed a textralia flywheel. Hope that helps some.
