using the evil skipshift for good???
Old Oct 15, 2003 | 08:21 PM
restoman45's Avatar
Default using the evil skipshift for good???
i was brain storming the other day, and i was thinking about how i used to hate skip shift b4 i disabled it a couple years ago. now i then started thinking what if we could use it for good...to prevent downshifting to certain gears at certain speeds...like preventing the 3-2 shift when u are at 75mph or a 2-1 above 40mph for example...can this be done?...and i was thinking it would be cool if it could prevent downshifts in every gear if u were over a certain speed...just wondering if it was possible.. that way i could powershift and not really have to be thinking about down shifting and blowing my motor.
Old Oct 15, 2003 | 08:36 PM
black_z's Avatar
Default Re: using the evil skipshift for good???
I actually had this exact same idea, I figured someone else has tried it out though. I am really interested to know if this would work.
Old Oct 15, 2003 | 08:38 PM
EVIL's Avatar
i thought 383lq4 had done something with it like that.
Old Oct 15, 2003 | 09:10 PM
P Mack's Avatar
Harlan was working on that a while ago. He called it drag CAGS, but i don't know if anything ever came of it. Maybe he'll get back to working on it after his twin turbo beast is done. http://www.harlan-engineering.com/store/new.html
Old Oct 16, 2003 | 07:45 AM
ZDOG's Avatar
ive heard of this too. maybe with edit yo could have that seldoid kick in at over 75. it would be a nice piece of security. do a search on "drag cags" this was talked about before.
Old Oct 16, 2003 | 09:06 AM
kp's Avatar
kp
from what I seen, even though I didnt study it and could be mistaken, there is a slot cut into the lever that guides the trans from 1st to 4th and the CAGS solenois has a pin that goes into that slot. If its positioned anywhere else and the CAG solenoid is activated it wont do anything except guide it from 1st to 4th (or the other way around) if the pin pops in the slot.
It can probably be changed if you take that lever off the trans, weld up the slot and make a new slot/ridge to keep it out of 1-2 if the solenoid is energized but to get the lever out the case has to come off the trans. Most people probably wont want to deal with that..
Old Oct 16, 2003 | 11:01 PM
restoman45's Avatar
hmm...it would be really nice if this gets made, or someone figures out how it could be done..
Old Oct 17, 2003 | 08:31 AM
kevin30thta's Avatar
I have done this with modified parts for some time now. Yes , it works well.
Old Oct 17, 2003 | 11:34 AM
restoman45's Avatar
dont leave us hanging...details details...
Old Oct 18, 2003 | 02:31 PM
991LE's Avatar
Disconnect the cags solenoid.
Install the skip shift resistor in the wiring harness.
Wire in a switch that hooks up to the CAGS solenoid. It is easiest to tap into the cigarette lighter power under the console and run the wiring through the shifter hole. Hook the switch up in a convenient location like on the dash, shifter or console.
Now when you are racing, energize the CAGS solenoid after shifting into 3rd gear. At this point you won't be able to shift into 2nd gear.
Old Oct 18, 2003 | 02:48 PM
MIGHTYMOUSE's Avatar
easier, go in ls1 edit and move the mph range to that during which you shift to 4th wide open and move to full load kpa and more than 110% full throttle position.. done
this will turn on skip shift just before the 3-4 shift and enable you to not miss 4th to 2nd.. then goes off shortly after you enter 4th.
Old Oct 18, 2003 | 03:21 PM
EVIL's Avatar
does this work dave?
sounds like it should, but is it on your car?
Old Oct 18, 2003 | 10:00 PM
restoman45's Avatar
very good ideas(i will try them out)...but it seems like they only work for the 3-4 shift, can they work for the 2-3 shift which im more worried about, lol thanks for the reply's!
Old Oct 18, 2003 | 10:09 PM
ZDOG's Avatar
hey 991le, you could use a windo switch for that also, correct?
Old Oct 19, 2003 | 02:00 PM
brian.. umm i dunno, i just thought if it my car wont start right now (no heads) but i would try it if it did!
i heard about your party, car will be going back together middle of next week, but then going away for a while after that.. so it won't be in attendance. sorry/
Old Oct 19, 2003 | 02:09 PM
EVIL's Avatar
damn, that sucks, i had the beer ready!
