ls1 and lt1 bellhousing the same?
Old Mar 6, 2009 | 05:21 PM
innovative induction's Avatar
Default ls1 and lt1 bellhousing the same?
can you swap a stock t56 from a 94-lt1 into a 99 ls1? I know GM changed the t56 in 98 and had it made in mexico, but does the ls1 share the same bellhousing as the lt1? the reason Im asking, I have a 99 ls1 automatic, and Even though I herd the automatics can handle more then the t56, its just not as fun to drive! I have a chance to get a good used t56 from a 94 trans am, for under $1000 complete, with everything I will need to do the swap. but I need to make sure it will work with the gen III blocks
thanks
Old Mar 6, 2009 | 08:46 PM
the_merv's Avatar
Veteran: Air Force
The LT1 style T56 & Bell Housing will NOT work with the Gen III Engines..the LT1 style is a pull-type setup, the Gen III's are a push-type setup. You will need a Gen III T56 & Bell Housing for what you want to do.
Old Mar 7, 2009 | 08:04 AM
Gen414's Avatar
thanks
I just finished up this swap, parts you need:
LS1 input shaft
LS1 Bellhousing
LS1 Midplate
LS1 Hydraulics
You can buy new, or used.
New:
Input $200
Bellhousing $300
Midplate $200
Or used like I did:
Input AND midplate $100
Mcleod SFI bell $224
Sold my LT1 input for $100
Sold bell, midplate and hydraulics for $85
Do the math, and I am in the conversion for @ $160 is all
Oh sorry, forgot teh hydraulics:
Slave came with my clutch for an extra $70
MC, I bought teh Tick adjustable on teh GP for $300 (you don't HAVE to buy the more expensive MC like I did though.
