No mees, no fuss bleeder line, no wrench needed
Well I had to change out my slave today. Did not want to fight with a wrench on the bleeder fitting or a mess of spilled fluid in the bell housing.
Here is what I came up with, line works as a wrench and a bleeder extension.
Front shot.........
Side shot............
Bleeder in the closed and stowed position. Held in place by a mount bolt.
Here is the bleeder in the open position, with a flex line installed no mess no fuss.
Front shot.........
Looks good, only issue that I see is that you will have to put a lot of fluid thru it to ensure that there is zero air in the system. You won't be able to see the spurts of air like normal.
That's why a Mity-Vac is awesome. Fill it with fluid, set the pressure and let it loose.
Thanks
Tired of having a mess inside the bellhousing, have had the idea for a while know but never put it into action.
Was able to carry out a normal bleeding process, looking for bubbles was not a issue. Might add when much quicker which made the wife a bit a little more at ease. Due the fact I was using her leg.
Thanks.......right now the only way to produce something like this. It would be slave specific. Due to the fact that each bleeder port stops at a different position. Trust me I tried this on the junk slave 1st on the bench. Then swapping the bleeder port to the new slave, clocking was off.
Thank you......Yes it is a clean T56 want to keep it that way.
Not sure how the OP did his, but brazing or welding will work and your Lincoln mig will do it. I welded a steel AN fitting on the end of a stock bleeder. Not sure the type of steel the bleeder is and it's not real happy about being welded on, but nothing that a grinder can't smooth down and it's not going anywhere.
